odd headlight problem
Old Apr 25, 2007 | 11:26 PM
panamagreen's Avatar
Default odd headlight problem
hiya, i own a '93 SL and of late have started having this weird problem with the headlights(as stated in the subject)
it seems that whenever i turn my car off after driving it around for a little bit
the headlights pop-up, usually about 15-20 minutes after i turned it off
it first did it every now and then and only when i had used the lights(night, rain, etc)
but now it seems that they pop-up regardless
was wondering if someone could help me out
or give me any info on why its doin this
thanks alot guys
Old Apr 26, 2007 | 01:27 AM
isiah's Avatar
Default RE: odd headlight problem
sorry that i really don't have any solution for your problem***********? many many more people on there specifically drive 3s's and i'm sure someone has experienced this.
but, to me it seems like maybe it has something to do with an alarm. but that is one absolutely wild guess
_isiah
**You cannot solicit another site in here. No site allows that!....Silver**
Old Apr 26, 2007 | 03:44 AM
though when i do stick the key in the door and turn it they lights go back down...
and the 3si sight wouldnt let me register with my email adress
Old Apr 26, 2007 | 11:22 AM
thestealth's Avatar
I bet this only happens when you lock the doors...
Old Apr 26, 2007 | 02:57 PM
Dusty Eclipse's Avatar
If theyre any thing like the lights on a Corvette, it may be the vacuum lines giving out once the pump is shut off long enough.
Old Apr 26, 2007 | 06:45 PM
isiah's Avatar
ORIGINAL: panamagreen
yeah, it won't let you if you have certain e-mails. like i think they could be called passport e-mails. if you could get a centurytel e-mail, i bet it would work because that's waht i have. but i don't know if they are free or what
_isiah
and if you put the key in and they go down, i think that would have something to do with the alarm. by anychance do you have keyless entry, but use the key for the door instead?
Old Apr 26, 2007 | 07:01 PM
94 3kgt sl's Avatar
i do and the doors lock themsleves sometimes. its not a big deal to me. it mostly happens in the winter time.
Old Apr 26, 2007 | 09:16 PM
kornkid1215's Avatar
i have a 93 vr4 and my lights did that too i cleaned out the connector plugs to the lights and it stopped doin it
Old Apr 27, 2007 | 03:13 AM
hiya,
thanks a bunch guys
i'll try cleanin out the connector plugs
...and i always lock my doors
Old Apr 27, 2007 | 12:12 PM
thestealth's Avatar
I think it has something to do with the factory alarm system. Have you ever been there when the lights come up? My RT does the same thing when I lock the doors. Sometimes the alarm will trigger, other times the lights just pop up. I don't lock my doors very often as there isn't anything in the car to steal and a car theif is bothered by locked doors so I just take my chances.
