problem with active areo
Old Apr 23, 2007 | 10:57 AM
kornkid1215's Avatar
Default problem with active areo
sooo last june my old vr4 engine blew then i replaced it over the summer. Before the engine went the active areo worked fine and after i put in the new engine it was all right also then the lite came on in the car for it and it wontt work anymore..... any ideas on what the problem could possibly be?
Old Apr 23, 2007 | 01:16 PM
VR4GARY's Avatar
Default RE: problem with active areo
Check to see if the front air dam drops when it is on. You only have to insert the key into the ignition, then press the active aero button. If it does, then it is probably the plastic link that pushes the spoiler up. It could be the motor itself, but that is less likely. If the front air dam does not drop, there is something wrong with your sensor or sending unit.
underpressure2003
Apr 24, 2008 08:47 AM
hatchetman9449
Apr 30, 2007 11:17 AM
EMonz57
Apr 20, 2007 11:43 AM
Doober247
Apr 3, 2006 01:51 AM
jimweee
Feb 20, 2006 11:07 PM
