Prospective 1991 GTO owner
Old May 28, 2009 | 08:44 PM
Matt_101's Avatar
Default Prospective 1991 GTO owner
Basicly what the title says, i am looking at buying a already imported and inspected gto. the price is $5000 if i want it , he was asking 6500.
heres the known issues with the car:
sun roof glass needs to reattached to the glass
shifter **** is stripped out
rotors are warped(steering wheel shakes under braking)
interior is rough and some things need to be secured
there are some scrates on the pain
there are vaccume leaks(the y pipe is cracked and there are cracked vacume hoses elsewhere)
the car idles at 2000 rpm instead of 1000rpm, this happned since the clutch install. I think it might be due to old hoses(vac/boost leaks)
Speedo does not work, does not move at all.
power seat does move front and back
Other information:
The only repiar done recently was the clutch and the clutch seems to hold well. i think this lends itself to the spedo and vac leaks mentioned above.
There is a boost guage in the car, which only reads zero - does not go into vac or boost. this means its broken or not hooked up.
i am bringing my own boost guage and compression tester tomrrow to check the car out.
the owner did the clutch install himself in his garage.
ODO reads 125 000 kms. spedo is broken though
owner does not know if the timing belts have been done.
Active aero is not working on the rear.
so, i was wondering the following:
Do you think its worth 5000?if not, what is a fair price?
What is considered good compression on these motors?
What is the stock boost setting?
How can i tell if it was factory turbo or someone turbo'd it along the way?
How long do these motors usually last if daily driven? km range.
How much does a timing belt job cost at the dealer? the one repair i do not want to tackle myself on a unformiliar engine.
i have searched and foudn some info, but i am decided to buy or not buy this car tomrrow so i would like some opinions before i dive in. i very much apperciate any help anyone provides. My last (and currently parked car) was a single cam turbo ka 240sx. i turbo'd it myself and subsaqunety grenaded it myself lol.
Old May 28, 2009 | 09:56 PM
rjr234's Avatar
Default gto
It sounds like your going to buy someones headache, It wont pass smog so unless you want a money pit forget this one, you can buy running nice one for that much money.But mabe you really want it.
Old May 29, 2009 | 08:39 AM
Girly VR4's Avatar
I wouldn't pay a dime more than $1200 for it. Walk away. For $5000 you can get a MUCH nicer TT/VR-4
Old Jun 3, 2009 | 12:51 PM
BEAT's Avatar
Do not buy it.
$6,500 you can buy yourself a better used car or slighltly new car for that price.
Buy a new one no headaches just payment of $250.00 a month with a $6,500 down payment IF your credit is excellent.
You are not the first owner it is hard to figure out what part of the car that has to be fix. if you are the first owner you know what is going on with that car.
Old Jun 8, 2009 | 12:16 AM
Mr.CTT's Avatar
well here is a little help and or what prices should reasonably cost although in some cases it could be unpredictable.
call safelite auto glass other than that no clue
take the boot off and pull the peice that moves and has the threading on it get a bolt with similar threading and weld it on, grind it, paint it black, put it back in and itll be good if not better than new. i actually did this to my car so that i could powershift at higher rpms easier (5k-7k) by extending it up but the reason i had troubles with that may have been because the syncro was on its way out. =p
rotors for front and back will run you in the 100s for oem slotted and drilled 2-300 if you look in the right places and pads i found at an awsome price here on clearence make sure you call to order and get someone who knows what they are doing else youll get the wrong ones. http://www.familycar.com/store/index...3+1125&Vi=1676 11329 4294963863&mk=Mitsubishi&md=3000GT&y=1993&Nr=AND(A ND(make:Mitsubishi,model:3000GT,year:1993),AND(uni versal:0))
wha?
there are some scrates on the paint
get a quote if you live in ohio i know a place that would give a fair price and does amazing work painter has painted and done body work for 20 years uses ppg products only and some of the ppg reps around here go to him for advice sometimes.
ebay y pipe costs 30$ itll do untill you crank your boost up get one with rolled edges.
i think the throttle cable adjustment is attached to the intercooler piping in the center under your hood (big silver square thingy is what ill call it since i cant think of the technical term for it ) its located furthest to the back give the cord a yank youll hear the motor rev find the adjustment and well... adjust it.
check for a blown fuse doubtful but possible clusters sell on ebay kinda cheap less than 100 or if i were you ide get a digital speedom like through prosport and install it.
ok racing seats all the way thy look bad @&& i do have my stock ones from my 1993 3000gt vr-4 if you want them ide be happy to sell them just hit me with an email ctt08@hotmail.com one is electronic with lumbar and the other isnt electronic. in pritty good condition ill send picks if your interested.
if your going for gto and not vr4 ide say its ok jew em a lil more if you can
N/A
mine was at 12 peak when i got it so ide imagine around that ive never met anyone that knew nor could i look it up
N/A all i can say is look for specs and or pics and use that to compare
mine blew around 100k but ide imagine the idiot that had it before me couldnt drive worth a beans there is an art to driving a 4wd car
N/A i think they sell these aftermarket also but go to 3sx.com or ipsmotorsports.net and look for prices before you go to the dealer check all 3 before you buy tho. also google is your friend.
good luck gtos are hard to come by around here ive never seen one up close so i can see why you might buy it for that it isnt too bad a price if the transmission, turbos, and motor are good. 3000gt vr4s book for 12k in good condition average miles.
Old Jun 9, 2009 | 05:26 PM
alan92rttt's Avatar
If your in the US don't buy that.
You can get a 3000GT or Stealth for the same price in better shape.
Old Jul 2, 2009 | 10:12 AM
reggieccrgto's Avatar
i have to agree with the folks above. dont do it keep looking something better will show up.
IndyEndeavor
Jan 10, 2013 07:01 AM
Offroadingmaniac
Jan 19, 2012 07:09 PM
chips
Dec 9, 2010 01:30 PM
dirkpitt73
Jan 28, 2009 07:35 AM
rgsoundguy
Aug 15, 2008 12:00 PM
