rumor or fact???
RE: rumor or fact???
Ask just about any VR4 owner what weight motor oil they use and you'll get the typical 5w-30 or 10w-40 or somewhere in between. What most owners don't realize is that the TT engine required 20w-50 as specified in the owners manual. This has LOTS to do with spun bearings! Owners just don't realize what they're doing...
Joel, CA
Joel, CA
ORIGINAL: EMonz57
You cant honestly say they dont spun bearings? come on how many 1G 6G72TTs have you seen do it.
I just had the 180K check up done on my 92 RT/TT, and since the pan had to be dropped to replace the oil pump, I had the rod bearings checked/replaced, they barely had any wear (after 180K). Quality oil and regular service intervals DO make a difference.
You mention being leery of the 1st generation 3S...good advice, but I'll take it one step further and say, be leery of ANY 13-15 year old sports car...
I've had both (still have the VR4) , and didn't have a problem with either. TheStealth is right about the spun bearings too. Modding a car can start all sorts of problems.. And preventative maintenance, that should be common sense.
ORIGINAL: mystic 3si
