Smoke after bov releases
Old Jun 11, 2009 | 03:10 PM
johhnnie's Avatar
Default Smoke after bov releases
Hi folks
Wonder if someone can help out , I have a 1991 mitsubishi got twin turbo , I recently changed the turbos from the stock 9bs to 13ts , Now the car drives ok if i drive without the bov releasing the pressure but when i give it some welly its gives a puff of smoke from the back just after the bov releases the harder i go the smoke cloud gets bigger .
Any ideas ? .
John
Old Jun 11, 2009 | 05:14 PM
Girly VR4's Avatar
bad turbos? is there oil in your IC pipes?
Old Jun 11, 2009 | 06:22 PM
dsm1990gsx's Avatar
What color is the smoke?
Old Jun 13, 2009 | 02:22 AM
johhnnie's Avatar
Hi
Its sort of greyish colour , When driving normal its ok and no smoke from the back , I believe the turbos i put on it have only done about 1500 miles and theres no oil deposits in the downpipes either , Im unsure if it could be the valve stem oil seals .
There is a bit but not a lot that you could say would make it smoke like it does .
I've done quite a bit of work on this car and would like to get to the bottom of this prob.
John
Old Jun 13, 2009 | 06:18 AM
Blck3G's Avatar
http://www.youtube.com/watch?v=uecmGqiY_nk
Look anything like that?
its oil being burnt in the exhaust stream.
If its that potent Id say your rings are done.
Old Jun 18, 2009 | 10:02 AM
Id say valve stem seals. I had the same problem on my talon only when i came out of boost
Old Jun 18, 2009 | 06:34 PM
dsm1990gsx's Avatar
X2, valve stem seals are very common.
douglaswelcome
May 27, 2010 12:05 AM
91ricerocket
Jun 15, 2008 05:39 AM
BrunoBoy650
May 31, 2006 07:39 PM
jap901
Jul 24, 2005 10:05 PM
badass91hatch
May 6, 2005 02:32 PM
