Stability
Old Mar 14, 2006 | 01:21 PM
wiggerman8860's Avatar
Default Stability
what can i add to my 3000gt to make it more stable at high speeds. when i get up to about 110-130mph, it feels like im gunna loose control and it shakes a little bit. what can i add to make it more stable at high speeds???
Old Mar 15, 2006 | 02:10 AM
alan92rttt's Avatar
Default RE: Stability
First check and make sure that all the stock suspension parts are in good shape. Check your Tie Rod ends, ball joints and struts/springs.
If everything checks out then you need to lookinto stiffer struts and springs.
Old Apr 18, 2006 | 02:36 AM
EdZorX's Avatar
You can also lower your ride, as lower cars are designed to be more stable at faster speeds due to decreased airflow underneathe your car that lifts it the faster you go. Also, if you are into hardcore speeding (i dunno!) then get a better wing that can put more pressure on your car, and last get better and smoother tires (this shouldnt make too big of a difference, but better tires are good for almost every measure of the car)
Old Apr 18, 2006 | 02:55 AM
alan92rttt's Avatar
Unless your a ricer or running at 180mph for long distances. plus don't waste your monty on a wing.
Old Apr 18, 2006 | 02:43 PM
EdZorX's Avatar
this is very true, i deem them useless also, unless you're talkin bout the 99 VR-4, with its "little EVO" wing, i would much rather have the 98 and under wing
ikeandtike
Sep 4, 2012 02:45 AM
