Swap my 6G72 with a 6G72TT
Old Jun 21, 2007 | 02:10 PM
Lingenfelter_C6's Avatar
Default Swap my 6G72 with a 6G72TT
I blew my engine recently and Im looking to drop a TT engine in my 3000 SL. On the site that Im planning on ordering from, they say that I will need a transmission from a VR4. Is that true?
Old Jun 21, 2007 | 02:27 PM
davidmitsusrock's Avatar
Default RE: Swap my 6G72 with a 6G72TT
this is not true...you can do the tt swap on an sl motor...it is the same motor...the dohc 6g72...all you need is tt parts to make it happen.
Old Jun 21, 2007 | 04:01 PM
Ok. Thank you. The site was saying that I needed a new transmission and I couldnt afford one now.
Old Jun 21, 2007 | 04:24 PM
94 3kgt sl's Avatar
actually this is not true. the motor for your sl has a different compression ratio as the vr-4, it is higher. 10:1 and 8:1 i believe. this swap has been done by some people on 3si but you cannot run as high boost on this motor than if you were to just drop a vr-4 engine into your car.
i want to do the same thing you are doing eventually though. i mean swap the entire motor instead of bolting on the parts. im just waiting for my motor to have some catastrophic disaster happen to it, since it just wouldnt be practical to make a project out of my daily driver.
ok so the smarter way to go would be the way you initially wanted to go. just swap the entire motor out. it will be much safer and you will save yourself alot of head ache. good luck man and keep us posted on the project.
Old Jun 21, 2007 | 04:40 PM
thestealth's Avatar
...to answer your question, yes, the tranny will bolt up fine. You should spend some extra bucks and get a LSD for the transaxle...
duster6g72
Oct 17, 2012 11:08 AM
Hondaciv92
Dec 29, 2008 04:16 PM
mitsu6g72
Jul 27, 2008 02:18 AM
2.0_V6
Nov 28, 2007 04:01 AM
eclipse96
Jul 21, 2006 12:39 PM
