traction
Old Mar 25, 2005 | 08:51 PM
xtremeone1998's Avatar
Default traction
Im looking for some kind of traction kit. Chevy has posi and ford has the trac lok , does anyone know of a positive traction kit so that both wheels will catch. I hate limited slip.
Buy the way i have a 92 stealth R/T 5 speed.
Thanx rex
Old Mar 26, 2005 | 02:13 PM
m3kgt_99's Avatar
Default RE: traction
I don't know what the deal is with your limited slip....obviously I don't have it... My car is a '99 base model too... so I don't know
Old Mar 26, 2005 | 05:21 PM
Patrick's Avatar
Administrator
im not sure if there is a sort of quiaffe you can get for the awd? i would think someone HAS to make some sort of locking differential....
Old Mar 26, 2005 | 06:24 PM
thestealth's Avatar
These cars have what is known as an open differential, ie, one tire will be the "torque" tire. You can get a limited slip insert (a quaiffe as Patrick mentioned) that will do a much better job distributing power to your front wheels. I believe it is the same one as DSM use. (basically the same trannies).
You can have a piece welded in the transaxle to make it a positrac, but every day drivability will be greatly compromised. It will put an undo amount of stress on the tranny and cause it to wear out much faster (when turning, the wheels rotate at different speeds, you will cook internals)
Old Mar 28, 2005 | 12:27 PM
Patrick's Avatar
Administrator
stealth..i know that for my buddys newly turbo'd 95 sebring, there is a more ghetto way to making it a closed diff...a "panther", or something liek that? a spring system that holds everything closed under power and works by means of the motion of the diff.?
Old Mar 30, 2005 | 10:10 AM
sir_gyugyu's Avatar
What you're looking for is a sperr differential or a torsen differential. Both systems are ok, but for the street I would recommend using the torsen since it is much more corner friendly. Sperr is OK, but you'll need not to over pre-torque it or else you will having hard times at sharp corners. Torsen works on the wheel spining speed ratio difference- if one of the driven wheels turns much faster than the other (loosing power to this wheel) than the centrifugal force due to the rotational speed difference will close the differential so you'll have two driven wheel instead of only one. Here in Hungary one torsen costs around 1,000 USD for an EVO6, but I saw many internet pages selling these goodies in America.
Old Apr 5, 2005 | 12:21 PM
thestealth's Avatar
Here is the ghetto way of doing it on a 3kgt. SpeedFreak racing
It is reported to work well, but I have no personal experience with them.
sunshinee
Jun 9, 2018 12:54 PM
johvig
15
Dec 9, 2007 12:15 AM
Boost_Bandaid
Dec 4, 2007 08:02 AM
vinceaton
Jun 11, 2005 01:16 PM
xtremeone1998
Mar 25, 2005 08:57 PM
