tranny or what?
Old Apr 28, 2008 | 06:52 PM
dirtysteve's Avatar
Default tranny or what?
I have a problem, when i start the car the motor sounds great, but once i put it into gear and start to take off the car starts to studer. It will do this through 1-4 but once i hit 5 gear the car acts normal. to explain how it feels is lilke, you are not giving it enough gas when you are letting out on the clutch, i have changed the plugs/plug wires, changed fuel filter. just need some help?
Old Apr 28, 2008 | 11:57 PM
militarymustang88gt's Avatar
Default RE: tranny or what?
check the ecu. buddys vr4 was doing that and then one day it didnt crank at all. had no fuel and spark and the computer didnt have the fuel map and timing map.
Old Apr 30, 2008 | 05:40 PM
dirtysteve's Avatar
thanks for the imput
Old May 1, 2008 | 01:49 PM
EMC 3000GT's Avatar
What kind of car is it? TT or NA?
Old May 2, 2008 | 01:50 PM
dirtysteve's Avatar
the car is a tt
Old May 2, 2008 | 02:23 PM
EMC 3000GT's Avatar
Check for a boost leak.
What kind of plugs did you use? What was the gap?
Old May 5, 2008 | 09:25 PM
dirtysteve's Avatar
speaking of the boost I notices oil on the top of the back trubo, (the one behind the intake pleum), the plugs were ngk and ngk plug wires
Old May 6, 2008 | 12:02 AM
EMC 3000GT's Avatar
How much oil?
Is it smoking?
Wanna get dirty? Check for shaft play.
Old May 6, 2008 | 11:35 AM
dirtysteve's Avatar
not a lot of oil, no smoking, but when i took the intake pleum off i noticed that the intercooler pipe that runs in the bolt that holds it to the turbo was gone.. Igoing to go this week to get a new one as soon as work slows down.. do you think that could be one of the problems..?thanks agin for all your help and input...if i have to get dirty I do...
Old May 6, 2008 | 12:23 PM
Plugs and wires, or a boost leak. One of the two.
venom3230
Jan 12, 2004 08:32 PM
MiataDooU
Nov 19, 2003 03:27 AM
cdipier2
Oct 27, 2003 05:24 AM
ikon_01
Sep 8, 2003 01:03 AM
proformance
May 23, 2003 11:54 PM
