Twin Turbo
Old Apr 11, 2008 | 10:44 AM
timbsktbll40's Avatar
Default Twin Turbo
What turbos will bolt up to the stock vr4 exhaust and everything else besides the 9b-tdo4?
Old Apr 12, 2008 | 01:25 PM
NiceVR4's Avatar
Default RE: Twin Turbo
13g's,13t's, 15g's,dr500's,dr650's,18t's, and 19t's which are the best for td04 manifolds in my opinion
Old Apr 13, 2008 | 07:53 PM
O thanks but what would be the cheapest. I'm not going to be pushing that much boost because i'm doing a TT conversion on my base model 3000. I have all the parts i need just trying to find the right Twin Turbos for the conversion.
Old Apr 14, 2008 | 06:39 PM
NiceVR4's Avatar
This guy sells 15g's for 700 on 3si thats pretty cheap
Old Apr 17, 2008 | 01:01 AM
BlinkRA182's Avatar
I wouldnt go too big since the n/a compression ratio is higher than the vr4. knock is no fun.
Old Apr 19, 2008 | 12:31 PM
So what would be the best turbos for a tt conversion?
Old Apr 21, 2008 | 05:10 PM
BrunoBoy650's Avatar
ORIGINAL: timbsktbll40
a vr4 swap lol.........
Old May 1, 2008 | 02:04 PM
EMC 3000GT's Avatar
the 13Gs are what I would reccomend but even the small 9Bs will give you enough traction headaches.
Old May 2, 2008 | 01:05 AM
vr4girl's Avatar
but the 13gs requre a good bit of modding to get to fit just right. believe me, i just went through that.
Old May 3, 2008 | 11:39 AM
Girly VR4's Avatar
The only way you should be having traction problems on 9b's, is if your suspension is SHOT or your VCU is fried or something. LOL
ORIGINAL: vr4girl
you might be thinking of 13t's.
The 13g's are plug and play. They're OEM mitsubishi turbo's. Unless you got some hacked ones or something...
