wanted turbo info for vr4
i am looking for any turbos that are larger than the stock 93 vr4 with the supporting mods or the mods i would need for larger turbos
any input would help please thanks |
Well, what size turbos are you looking for? What power range are you looking to make? There are dozens of options, but we need to know what your goals for the car are.
honestly im looking for t19's i want to make around 500-600 hp
thank you
and any clue for supporting modifications for these gzp's?
The supporting modifications are listed in the second link I believe. It is our basic recommended set-up if you are looking to run it up to 600AWHP. However, it can be tailored to your specific needs/goals for the car.
This does not take into account basic maintenance that may need to be done to your engine, and/or drivetrain reinforcement. You are a 5spd, so, a transfercase bracket (or billet transfercase housing), and hardened output shaft are a necessity. Kit includes the following items GZP 747 Billet TD04 Turbos PTE 680cc Fuel Injectors Walbro 255HP Fuel Pump Fuel Pump Hotwire Kit MAF-T w/3.5 GM MAF GZP Front Mounted Intercooler Kit South Bend DXD Stage 3 Clutch Kit Blitz DSBC Electronic Boost Controller AEM Methanol Injection Kit HKS SQV Style BOV Tanabe Blue Style Exhaust |
ok so besides the drivetrain, will there be anything i should do to my engine?
You're a 93, so you already have the forged crankshaft, metal headgasket, and 4 bolt block. Just make sure it has the basic maintenance up to date, and you should be just fine.
I received your email, I will reply a little later this afternoon. |
i don't know what your intercooler set up looks like, but, you'll at least want an aftermarket y pipe, as the stock one will blow off the second you start boosting on anything bigger than 9b's.
-so you'll want a y-pipe that you connect to the throttle body with a coupler. -your intake pipes (the pipes that go from the bubble that connects to the filter THAT run into the cold side of the turbos. price matched parts sells a set for 100 bucks, and should come with couplers. all three of those pipes will blow off once you turn up the boost. good luck! _isiah |
