Where is the Pressure Relief Valves location? HELP
Old Jul 14, 2006 | 02:42 PM
enzo_hashmat2006's Avatar
Default Where is the Pressure Relief Valves location? HELP
I need to know where the Pressure Relief Valves are located on a 1992 3000gt. Please
Old Aug 9, 2006 | 06:18 PM
Default RE: Where is the Pressure Relief Valves location? HELP
bump. come on guys noone knoes where this valve is?
Old Aug 9, 2006 | 08:02 PM
Manybrews's Avatar
its part of the oil pump assembly.
Old Aug 11, 2006 | 05:28 PM
so if i wanted to replace the valve i would have to replace the complete oil pump asembly.
Old Aug 11, 2006 | 06:37 PM
Manybrews's Avatar
why on earth would you want to replace the relief valve? they NEVER fail. theres nothing to fail on them.
Old Aug 23, 2006 | 01:09 AM
Because the motor oil gauge goes up really high when the car is in gear and after a while the engine overheats. but the weird thing is when the car is at a low RPM the motor oil pressure stabalizes, that only when the car is under like 1,000 RPM.
Old Aug 23, 2006 | 08:19 PM
Manybrews's Avatar
oil pressure naturally fluctuates with engine RPM and temperature. it will be very low at idle when its warm (as low as 10-12 psi), but very high when revved and cold (as much as 100 psi).
it also will have nothing to do with the car overheating.
Old Aug 25, 2006 | 12:53 AM
I know what happens, and i know something is wronge with it. i dont mean to get into you face or anything. OK go to http://www.nrauto.com/gaugeimages/3564-EL_t.jpg and look at the center gauge (oil). notice that there are four marks on it. one is black, one is red, and there is one on the lower side and one on the upper side. When my car goes over 2,500 RPM the pressure goes up to the line right under the red line. And when this happens, and i drive for maybe 3-5 minutes, the water temp. goes up and the engine overheats. I hope this helps. The car is fine when i am not in gear or not revving it, the oil temp. stays in the middle, but even the slightest amount of revving brings it up to that point. I couldn't get it. maybe there is something i am missing.
Old Aug 25, 2006 | 03:41 AM
superinflamo's Avatar
checkout
http://www.socal3s.com/forum/index.php
they know teh 3000 GT and Stealth like no other
daniel
Old Aug 25, 2006 | 07:50 PM
Manybrews's Avatar
are those the actual gauges you're using? meaning has someone changed from the factory gauges?
