01 diamante transmisson problem
hello everyone,
I am a supra owner/enthusiast looking to pick up a diamante for a DD and looking for some transmisson information. The car that I'm looking at does not move when put into drive, the fluid is good, no burnt clutch pack smell etc. I believe its something electrical or pump related due to the fact the current owner just stopped at a light then it would not move from there. Is there any quirks with wiring or other information that could help me? thanks for your help. -Jesse |
if it doesnt move at all, it probably mechanical. even without any electronics, the trans should have 3rd gear and reverse.
If you have no foreward or reverse I'm betting the pump took a crap. Try hooking a pressure gauge and see what your pressure is.
Originally Posted by dsm1990gsx
(Post 243329)
Would you have any idea on how much a pump would run? thanks |
I have no idea, but there would be a lot of labor since the trans has to come out.
hey, mine has the same problem. when you turn the car to the on position, but not start it, and you shift out of park, do you get a quiet buzzing sound from the engine for a few seconds? mine does that and im not sure what it does.
also, which pump are you guys talking about? |
Originally Posted by ninedice
(Post 243410)
hm, this wouldnt also happen to be called a torque converter would it? or is this something else?
