Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
01 diamante transmisson problem
Old Apr 27, 2009 | 09:38 PM
thesupraguy's Avatar
Default 01 diamante transmisson problem
hello everyone,
I am a supra owner/enthusiast looking to pick up a diamante for a DD and looking for some transmisson information. The car that I'm looking at does not move when put into drive, the fluid is good, no burnt clutch pack smell etc. I believe its something electrical or pump related due to the fact the current owner just stopped at a light then it would not move from there. Is there any quirks with wiring or other information that could help me?
thanks for your help.
-Jesse
Old Apr 27, 2009 | 10:23 PM
Manybrews's Avatar
if it doesnt move at all, it probably mechanical. even without any electronics, the trans should have 3rd gear and reverse.
Old Apr 28, 2009 | 11:52 AM
dsm1990gsx's Avatar
If you have no foreward or reverse I'm betting the pump took a crap. Try hooking a pressure gauge and see what your pressure is.
Old Apr 29, 2009 | 10:45 AM
yea, thats what I was thinking too. because if it was something mechanical, there would be some sort of warning, plus the fact the the ATF is very clean. That will be the first thing I will check.
Would you have any idea on how much a pump would run?
thanks
Old Apr 29, 2009 | 11:59 AM
dsm1990gsx's Avatar
I have no idea, but there would be a lot of labor since the trans has to come out.
Old Apr 30, 2009 | 01:26 PM
ninedice's Avatar
hey, mine has the same problem. when you turn the car to the on position, but not start it, and you shift out of park, do you get a quiet buzzing sound from the engine for a few seconds? mine does that and im not sure what it does.
also, which pump are you guys talking about?
Old Apr 30, 2009 | 11:00 PM
I'm talking about the ATF pump in the trans. Automatics shift using accumulators, when the accumulators fill up with fluid and gain pressure, it kicks it into the next gear. Without that pump causing the ATF to move you will not move anywhere. I messed around with modding autos for the supra including the accumulators and valve body, but got sick of it and put the 5spd in awhile ago.
Old May 1, 2009 | 12:09 AM
ninedice's Avatar
hm, this wouldnt also happen to be called a torque converter would it? or is this something else?
elmiserable
Jan 20, 2009 08:13 PM
BLAZE GS
1st Generation
Oct 31, 2007 04:40 PM
max3
Jul 21, 2007 04:46 AM
kobashi
Dec 15, 2005 03:47 AM
tmparsons02
Jul 19, 2005 10:18 AM
