Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
2002 diamante ls 3.5
Old May 26, 2019 | 05:34 PM
dbc2065's Avatar
Default 2002 diamante ls 3.5
Hoping for some guides recently purchased with 123,000 very clean car inner and the outer engine runs and sounds great for 300.00 everything works but transmission issues codes are 31 32 34 36 PO codes were saying either open solenoid or stuck TCC. In drive flashes back and forth between neutral either way, hot or cold engine you can feel it go into gear just won't move. Has an internal filter, not spin on change tranny fluid same results. Car will start in park and neutral I've been reading so much with different causes should I take a chance and find used trans controller? I read coolant can cause failure I've read tcm is integrated with ECM if found a used ECM would there be any issues with anti-theft? could you guys give some ideas or insight? maybe should find used tranny?
david
elmiserable
Jan 20, 2009 08:18 PM
elmiserable
Jan 20, 2009 08:13 PM
IceEyes
May 11, 2006 09:13 PM
IceEyes
Apr 20, 2006 06:29 PM
justinmh00
Jan 31, 2006 11:55 AM
