94 LS radio removal
how do i remove the radio on my 94 LS?
RE: 94 LS radio removal
anyone out there have any info on removing it ive look at it and cant seem to tell....I assume the woodgrain comes off but i dont know how to get that off even...I know my stuff about cars I went to school for automechanics and i hope to land a career in the field
Trim is always a pain. The engineers always find a way to interlock it so you need a puzzle solver to remove it. From my experiance there are either clips that will release if you pry them and/or a couple of screws as well. Don't use a screwdriver as they tend to mark the plastic because they are too narrow. Use a putty knife or something wide and thin. The radio might need a pin that you insert on either side to release clips that hold it in place, or it could just be screwed in. My Ford has two clips on either side. I use a bent piece of coat hanger to insert, bend, and remove.
Hello Billard
(1.) Remove center console. Two screw each side (front & back) and two under the ash tray. unscrew the light bulb under ashtray. remove center console. (2.) Remove simulated wood trim over radio. two screws at bottom. Detach two electrical connections to cigerette lighter and unscrew cig light bulb. Top is held in with two clips each side. lift from bottom and pull out from top and here's some photos to help http://www.diamanteowners.com/compon...60545/catid,3/ TG |
ORIGINAL: LRuff98163 Hello Billard (1.) Remove center console. Two screw each side (front & back) and two under the ash tray. unscrew the light bulb under ashtray. remove center console. (2.) Remove simulated wood trim over radio. two screws at bottom. Detach two electrical connections to cigerette lighter and unscrew cig light bulb. Top is held in with two clips each side. lift from bottom and pull out from top TG :) |
