Manual conversion of a diamante
hi can anyone tell me if its possible to convert my 1995 diamante to a manual. I asked at the mechanics and they said it cant be done.[:@]
RE: Manual conversion of a diamante
yes you can, parts you will need will include,
Manual trans, Clutch, and brake pedal assemblies. Clutch master cylinder. Brake booster, hydraulic lines, shifter cables/rods, manual model center console. manual model gauge cluster, shift boot, shift arm, shift knob, flywheel, mounting hardware, back-up sensor, and harness. axles, (maybe new hubs too, if the new axles have larger splines) manaul model trans mounts. re-build kit for the clutch slave cylinder, and master cylinder. any related clips, or harnes clips you need. |
