Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Manual conversion of a diamante
Old Feb 7, 2007 | 11:11 PM
mitsitania's Avatar
Default Manual conversion of a diamante
hi can anyone tell me if its possible to convert my 1995 diamante to a manual. I asked at the mechanics and they said it cant be done.[:@]
Old Feb 26, 2007 | 10:46 PM
soundcolor's Avatar
Default RE: Manual conversion of a diamante
yes you can, parts you will need will include,
Manual trans, Clutch, and brake pedal assemblies. Clutch master cylinder. Brake booster, hydraulic lines, shifter cables/rods, manual model center console. manual model gauge cluster, shift boot, shift arm, shift ****, flywheel, mounting hardware, back-up sensor, and harness. axles, (maybe new hubs too, if the new axles have larger splines) manaul model trans mounts. re-build kit for the clutch slave cylinder, and master cylinder. any related clips, or harnes clips you need.
sigmadrift
Jan 22, 2010 11:14 PM
djfrog2001
May 5, 2009 12:52 AM
luka
Sep 19, 2008 04:20 AM
EclipSe Tuner 95
May 4, 2007 12:02 PM
tattoogrif
1st Generation
17
Jun 17, 2006 01:37 PM
