Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
messed up the electronics, HELP!!!
Old May 1, 2015 | 10:32 AM
Raider's Avatar
Unhappy HELP! i messed up the electronics
today when I went to jumpstart the car, I hooked up the jumper leads backwards and fried the 120 amp fuse under the hood. I replaced that, but now the radio, clock, and the gauge lights aren't working. the gauge fuse under the dash was blown, I replaced that, but still no lights.
what can i do now besides replace the gauges? is there something else that controls all these things that i need to replace now? this is my bosses daughters car, so i need to get it figured out.
Old May 1, 2015 | 03:57 PM
Raider's Avatar
the signal lights work, the high beam light works, its just the clock, the radio and the speedo/tach lights that are not working.
should I try replacing the speedometer assembly to see if that fixes it? maybe each component is fried?
could it be the ecu that's fried?
anyone have ANY idea's???
Old May 7, 2015 | 09:59 AM
Diam2002's Avatar
Everything is fused for protection, therefore I would not start replacing components without verifying all fuses first. I do note that in the electrical schematics that the Audio, Cruise, Center Display,power antenna, and clock operate off the same fuse link.
Old Jun 28, 2015 | 07:39 PM
Antihero6396's Avatar
There is a little yellowish box in your fuse box under the hood. It has 2 fuses in it. Sometimes it pops up to prevent the fuses from blowing. I had the same problem and pushing that down fixed it.
jmil
May 12, 2008 04:26 PM
2nd g eclipse gst
Dec 11, 2007 06:46 PM
xLoveMeXoTenderX
Jul 26, 2007 10:21 AM
max3
Jun 28, 2007 09:29 PM
unreal23
Jun 24, 2005 02:07 PM
