Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Need help replacing power steering pump
Old Mar 26, 2014 | 03:20 PM
woniell's Avatar
Default Need help replacing power steering pump
I have a 1994 Diamante LS with SOHC 6 cyl 3.0L engine. I need to replace the power steering pump, and I have a dumb question. How do I remove the power steering pump drive belt? I think there is a tensioner just behind and below the pump, but wanted to make sure if this before I started messing with it. I am assuming I just loosen the bolt to lessen the pressure on the belt. Anything I need to be aware of before doing this.
See picture below:
Thanks in advance.
Walt
Old Mar 26, 2014 | 04:18 PM
jkeaton's Avatar
See that nut in the middle of the tensioner? Find a socket that fits it, put a long extension on it and rotate the tensioner pulley away from the belt to relieve the tension. Use caution though, it's under a lot of tension. You move the entire pulley out of the way, you dont remove it, just rotate it.
Old Mar 26, 2014 | 04:19 PM
If this belt does not also drive the alternator, and that doesn't have an adjustment on it, then there's likely a spring loaded tensioner pulley somewhere accessible.
It should be obvious, you would put a wrench on it, turn it, and you'll feel it's spring loaded. Simply apply tension to it while pulling the belt off, and shazam, you're golden.
Old Mar 26, 2014 | 04:23 PM
woniell's Avatar
Thanks guys
Old Mar 28, 2014 | 12:42 PM
woniell's Avatar
Default Update - Power Steering Pump Question
See the photo below. I think I need to loosen the nut in the center of the tenionser, then turn the "adjusting screw" to loosen the belt. Any thoughts?
Old Mar 28, 2014 | 02:17 PM
jkeaton's Avatar
Thats not the same pulley as the first photo?
Old Mar 28, 2014 | 02:41 PM
woniell's Avatar
It's the same one pulley, but looking at it from above. When I got out my flashlight, I saw what appears to be an adjustment bolt. At least that's what it looks like to me. I may be wrong, but want to see if anyone else had any ideas.
Tennysballs
Apr 25, 2012 11:58 AM
bennymax
Sep 9, 2007 07:48 PM
willdue
Jul 18, 2007 02:26 PM
Dookitchen
May 31, 2006 10:12 PM
newspeed
Nov 25, 2005 04:44 PM
