noisy startup
i have a 2001 Mitsubishi diamante which makes a clacking sounds at first start up then goes away after couple mins.what could this be and how to fix or how much could it cost to fix? please help
You should check the belts and see if they are loose or cracked. Belt noises and whining with the power steering pump on this vehicle is common. The noise could be from the belt is too tight or the pump fluid is too low.
Seriously. Wouldnt bother.
XBMRX
Jun 15, 2007 11:15 PM
