removing door panels
go easy. find all screw cover panels, there may/will be screws underneath. Start at the bottom rear corner after all the screws hidden and visible are off. Pry straight off at the bottom and work around the edges to pop all the panel clips. The whole panel should feel loose and floppy while it's still hanging at the bottom edge of the window. If there's still a screw the panel clips will be harder to pop. inner handle cover may have to slide forward after screw is out. After all clips are popped pull elec connectors then lift the back end of the panel straight up to clear the groove by the window then back to clear the outer mirror mount area. It may also help to pop off the outer mirror inner cover.
