Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
removing door panels
Old Mar 9, 2009 | 08:48 PM
chickhenn's Avatar
Default removing door panels
I need to remove a door panel on a 2002 in order to change out the speaker. Any advise or wisdom?
Thanks
Old Mar 9, 2009 | 11:49 PM
NWM_Tech's Avatar
go easy. find all screw cover panels, there may/will be screws underneath. Start at the bottom rear corner after all the screws hidden and visible are off. Pry straight off at the bottom and work around the edges to pop all the panel clips. The whole panel should feel loose and floppy while it's still hanging at the bottom edge of the window. If there's still a screw the panel clips will be harder to pop. inner handle cover may have to slide forward after screw is out. After all clips are popped pull elec connectors then lift the back end of the panel straight up to clear the groove by the window then back to clear the outer mirror mount area. It may also help to pop off the outer mirror inner cover.
Old Mar 10, 2009 | 12:04 AM
NWM_Tech's Avatar
Audioquest
Sep 14, 2007 12:38 PM
atown420
Jun 13, 2007 03:00 PM
Dusty Eclipse
Mar 15, 2007 01:40 AM
NubianSithLord
Aug 23, 2006 09:38 AM
JENNE527
Oct 16, 2005 02:04 PM
