Mitsubishi Eclipse & Eclipse Spyder For years, the Eclipse line has stood for cutting edge styling and performance at an affordable price.
Help with Distributor on 2000 Mitsubishi Eclipse?
Old Nov 22, 2013 | 03:18 PM
Robbie4545's Avatar
Default Help with Distributor on 2000 Mitsubishi Eclipse?
My son has a 2000 Mitsubishi Eclipse 3.0 v6 About 3 months ago ,he replaced the intake gasket cause there was a bolt missing on intake and he thought it had a broken bolt in it, but it wasn't, and after a month it started bogging down and idling rough .Thinking he might have did something wrong , I replaced it again, and also the sparkplugs but still didn't fix it. so I Took off cap and rotor and plastic cover behind rotor and there was oil in there ,so I cleaned it out good and replaced cap and rotor, and it ran great for about two weeks and started doing it again ,so today I cleaned it out again and it runs great so i'm guessing its the oil inside the distributor making it lose contact some how. Has any one had this problem before ? Is there an o ring inside of it that can be replace? I know there's one on the out side of distributor housing were it goes into the head. any advise would be great. thanks
Old Nov 22, 2013 | 04:18 PM
mxmikie's Avatar
sounds like the bushings in the housing are worn out time for a rebuilt dist
Old Nov 23, 2013 | 02:19 AM
Akzle's Avatar
take rocker cover off, put at tdc, take hold down/adjust nut off dizzy, pull dizzy out, check for play in drive pinion, if no, replace oring.
Old Nov 25, 2013 | 08:23 AM
Robbie4545's Avatar
Thank you for the advice I haven't messed with it yet but will let ya'll know what happens when I mess with it.
sweezy18
May 24, 2016 06:43 AM
Rynow JDM
Jan 13, 2016 06:04 PM
arrowunderworld
Apr 10, 2012 05:05 AM
LP
Mar 10, 2005 02:40 AM
myspyder
Jun 8, 2004 09:14 PM
