2004 Endeavor transistor or resistor?
Old Jul 25, 2011 | 11:27 PM
tremayne's Avatar
Default 2004 Endeavor transistor or resistor?
My blower motor stopped working suddenly and I'm trying to replace the blower motor resistor but am unable to locate it (no ac in Arizona in July!).
I pulled out the glovebox and located the transistor just fine, but no such luck on the resistor. I got a schematic from the parts counter at Mitsubishi, and it shows a resistor in mid air without a home (86347). Anyone know where in the world this part is? Thanks!!
Attached Thumbnails 2004 Endeavor transistor or resistor?-heater-unit-piping.jpg
Old Jul 26, 2011 | 08:12 AM
rfairch1's Avatar
Default Resistor or transistir
You have one or the other.
Have you also checked the two fuses and tested the blower!?
Old Jul 26, 2011 | 05:15 PM
tremayne's Avatar
Thanks. What I've done so far:
  • Tried a known working blower and it reacts the same way as the original; rotates a few times when you turn the car on but then nothing
  • Swapped out the front blower relay in passenger fuse box with the one above and below, but no improvement
  • Fuse @ location 10 in the engine fuse box was ok
I assumed since these can be eliminated, the transistor would be the issue?
Old Jul 27, 2011 | 06:17 AM
rfairch1's Avatar
Default Transistor
Since you have power, prob not a fuse then. I although there is one at location 19 or 20, I need to look it up. Can test the blower by applying voltage direct, but again, and using the swapout should be fine for that. One other component is the ecu, but the resistor is by far the most common failure.
Old Jul 27, 2011 | 06:20 AM
rfairch1's Avatar
Default Transistor
I just noticed you said fuse box in engine comp.
Fuses I referred to are on driver side, dash fuse box, just for info.
Old Jul 27, 2011 | 10:08 PM
tremayne's Avatar
Yep, transistor was the issue, thanks for the help! Installed a new one and the ac unit worked like a dream. I was a bit nervous, because I knew I couldn't return the part since it was electrical. Is there any way that I could have tested the transistor without the risk of throwing a new part at it?? I know that someone else will come along with a similar issue.....
bigchr
Feb 5, 2012 07:58 AM
Ravanne
Jan 27, 2009 11:02 AM
oh_what_up
Jan 13, 2008 04:59 PM
f1fever
1st Generation
23
Oct 19, 2007 07:27 AM
mubaiwai
Mar 2, 2007 04:41 AM
