2004 mitsubishi endeavor cylinder 3 misfire TRIED EVERYTHING! PLEASE HELP
Old May 2, 2013 | 02:13 PM
jay964's Avatar
Angry 2004 mitsubishi endeavor cylinder 3 misfire TRIED EVERYTHING! PLEASE HELP
I keep pulling a cylinder 3 misfire code
i have changed coil twice. First one was an after market that overheated so i exchanged it and swapped it with a factory coil from another cylinder. Still a misfire.
New plugs , new coil boots, changed valve cover gasket and plug well seals. Swapped injectors from cylinder 3 and 4. Still a misfire.
Can anyone tell me what is roasting the coils on cylinder 3.
I read somewhere that someone had a bad ground on ground number 11 which was causing the coil to overheat. Can anyone shed light on this. Any help is greatly appreciated. Thank you in advance. I have pulled the intake plentum countless amount of times and cant pinpoint the problem.
Old May 2, 2013 | 05:57 PM
Check the wiring harness, make sure there are no shorts
You can also do a compression test, and see if cylinder three is dead/mostly dead. That'd cause a misfire.
jaystihl
Aug 18, 2021 06:06 PM
morganh
Jun 15, 2015 02:07 PM
frankc
Jul 8, 2011 08:54 AM
tearz4evr
1st Generation
Jul 3, 2009 05:16 PM
dnau
Apr 24, 2005 05:12 PM
