2007 Endeavor Power Window Problems
I have an 07 Endeavor SE and both my passenger side windows will not operate from the switch at the door as well as the main drivers switch. At times they will go down when the switch is pushed but they will not come back up. Any ideas on what the problem is? I have been told it may be a power window relay, not sure where that is.
Any help will be greatly appreciated.
The switch must be plugged in at all times. The window will not operate with it unplugged (it is wired in series). Make sure both the master switch and the passenger are plugged in. Then, with the passenger switch pulled out of the door, take a piece of wire or a paper clip and short together pin 6 (Red with Black stripe) and pin 7 (Yellow with Green stripe) and see if the window responds to this.
johnny_truelove
09-15-2008 02:17 PM
tunit7
07-19-2005 08:09 PM
06, 2007, 2010, cable, control, disconnected, endeaver, endeavor, mitsibishi, mitsubishi, power, problems, relay, switch, window
