Endeavor 2004 A/C Issues
My a/c was working before, but when I would turn to the left I would hear a knocking noise coming from under the glove compartment then I would see water leaking, now the a/c no longer blows on any setting. The only time I get any a/c is when I leave my a/c button turned on auto and I crack the back window and am driving on the freeway, as soon as I stop it also stops....the rear a/c blows fine....
also my left rear window made a popping noise a while back and then the window went down all by itself and I couldn't get it to stay up anymore...
any help would be appreciated....
thanks
thanks
Hi.
Not quite sure about the AC issue, but I would be willing to bet that the rear window issue is a power regulator. Do you still hear the motor running in the door when you try to activate the window? If so, then I'm 99% sure it's the regulator. Each window has its own regulator; I think I paid about $80 for a new one (you could prob get it cheaper online somewhere).
I've had two go out myself on my 2004 Endeavor. It seems to be a common issue with this model.
