Errores en scan de mi Mitsubishi endeavor 2006
Old Mar 29, 2025 | 05:21 PM
Maye's Avatar
Default Errores en scan de mi Mitsubishi endeavor 2006
Buenas tardes lleve a escanear mi Mitsubishi endeavor 2006 ya que se le encendió el check engine y arrojo error U1073 y U1120 , que puede ser?
Old Nov 5, 2025 | 01:27 AM
Mapons's Avatar
Default rESPUESTA A TUS CÓDIGOS
Hola que tal, apenas entré hoy despues de meses y veo tu pregunta, cuento con dtc codes de Mitsubishi y dicen lo siguiente:
DTC: U1073
TPCM
Year: 2010
Model: Endeavor
Engine: 3.8LV6 VIN S
Transmission: All
Bus Off (Multi-Center Display Unit):
The diagnostic trouble code will be stored when the center display unit ceases communicating once (i.e. bus off) and returns to
communication from "Penalty mode".
NOTE: If DTC U1073 is set in the multi-center display unit (middle grade type), always diagnose the CAN bus lines.
WARNING: Whenever the multi-center display unit (middle grade type) is replaced, ensure that the power supply circuit and the
ground circuit are normal.
Possible Causes:
• The wiring harness or connectors may have loose, corroded, or damaged terminals, or terminals pushed back in the
connector
• Malfunction of multi-center display unit (middle grade type)
Old Nov 5, 2025 | 01:28 AM
Mapons's Avatar
Y este para el otro código:}
DTC: U1120
TPCM
Year: 2010
Model: Endeavor
Engine: 3.8LV6VINS
Transmission: All
display unit (middle g ide type) communicates
Failure Information on Powertrair
The multi-center mi
information is sent to the powertrain co
Possible Causes:
connector
• Malfunction of powertrain control
Control Module (Related to Engine):
with the powertrain control module via CAN bus line. If failure
trol module, DTC U1120 will be set.
module
center) display unit (middle grade type)
David Lane
Nov 22, 2019 08:55 AM
latchis
Aug 20, 2013 02:15 AM
bordermec
Jul 18, 2013 01:09 PM
tomaszww
Jul 29, 2009 06:16 PM
