How to Pull the Rotor Off???
Old Jun 6, 2009 | 12:00 PM
Southernguy's Avatar
Default How to Pull the Rotor Off???
I need to change the Rotor on my 06 Endeavor... I have already taken every thing off... brakes, calipers and the large nut... It looks like (2) small holes are threaded and some type of pin might be in it... Maybe dowl pins??? My brother gave me a wheel puller... I applied a little pressuer, but thought I would ask the question to you before I broke something.
Thanks in advance for any feedback. Jimmy
Old Jun 6, 2009 | 07:32 PM
Default Answer to how to remove Rotor
After approx. 4 hours of trying to remove the rotor... I decided to go to AutoZone and see if they could help. A very helpful man told me all I had to do was screw (2) 7 mm bolts in the threaded hole... no need for any puller or anything else. I purchased 2 screws for about $2.00 and screwed them into the tapped hole... screw each screw till they touch... then apply pressure rotate between the two. The rotor poped off after about 5 turns... so simple when you know how. My second rotor took aprox. 45 min. to complete everything. Maybe this will save someone some time...
Old Jun 9, 2009 | 08:51 AM
BEAT's Avatar
great job
Old Jun 17, 2009 | 10:15 PM
jgbrules's Avatar
my advice to you is buy a service manual from mitchell. or subscribe to a website called alldata.com. best aftermarket website on the planet. all of there info was taken from the manufacturers service manuals. mitsubishi doesnt make paper manuals anymore.
newoutlanderfan
Jun 25, 2013 05:29 PM
paintballproam
Jul 21, 2006 01:46 AM
EMonz57
May 4, 2006 01:14 PM
petro4411
1st Generation
Nov 24, 2005 03:01 PM
rogo_gst
May 18, 2005 08:38 PM
