I am getting the code for lean in bank 1 and 2
Old May 2, 2021 | 01:20 AM
Bigjjust's Avatar
Default I am getting the code for lean in bank 1 and 2
I hav a 2008 endeavor and I am getting the code for lean in bank 1 and 2, I have replaced mass air flow sensor. Could I be the fuel filter or o2 sensor? Any one have any suggestions, and if it is the fuel filter where is it located? I cannot find it anywhere?
Old May 5, 2021 | 05:08 PM
whilst01's Avatar
Hi, Fuel filter will not cause those codes. I highly doubt that 'both' Ox sensors went bad at same time.
> Why did you replace MAF? Running poorly?
> Are you sure there are NO leaks when you installed MAF sensor ?
Since 'both' banks are showing lean, there must be a common fault that would apply to both.
Leak 'after' MAF, leak in intake manifold, vacuum hoses...
Check all those before throwing parts at it.
Also, Google " lean- both banks", and fault codes for potential faults/remedies.
HTH.
Ab1media
Aug 27, 2020 05:10 PM
yanclan
Sep 6, 2015 02:21 PM
council718
Jan 22, 2014 05:42 PM
drakon
Oct 23, 2007 07:08 PM
melsa1
Oct 30, 2004 08:08 AM
