Endeavor wiring diagram?
Old 09-28-2017, 06:23 PM
Andrewryanj's Avatar
Default Endeavor wiring diagram?
Anyone have a wiring diagram for 2004 Endeavor? Fuel pump not making noise, but it runs when jumped with 12 volts. Both relays click. Is there a fuel shut-off switch somewhere?
I'll check the MAF sensor tonight.
It was running fine and suddenly wouldn't. Threw codes for camshaft sensor and crankshaft sensor. I replaced them both, but only cranks- won't fire.
I do have an aftermarket viper alarm. Could the starter disrupt malfunction and cause this?
Old 09-28-2017, 08:04 PM
Also, it is stuck in park. I can't shift into anything else. It's an automatic.
Old 10-25-2017, 02:32 PM
1dog87's Avatar
Default What ever happened?
I have the same problem with my endeavor the only thing it happened after my power steering belt broke
Old 10-25-2017, 03:57 PM
My timing had jumped two or three teeth. A mouse made it's home inside the timing cover and got smooshed in there. I redid the timing and it started right up.
Old 10-25-2017, 04:12 PM
1dog87's Avatar
Talking thanks
I will check timing
djsmear
04-03-2005 05:14 PM
Punisher
03-07-2005 02:06 AM
aznbballa4lyf
01-01-2005 03:44 PM
enrique
11-29-2004 01:29 PM
Havocprez
05-05-2004 07:54 PM
Quick Reply: Endeavor wiring diagram?
