Misfire Help
Old Dec 1, 2009 | 01:51 PM
4never's Avatar
Default Misfire Help
Happened to be a cold morning and my Endeavor (07) misfired. It knew it when the check engine light came on since it has happened before. I went and got it checked out at Autozone (misfired cylinder 5). I'm not really mechanical inclined but do have basic knowledge about cars. The autozone guy told me to give it some time and see if the light will go off. Is there any way to reset the check engine light or does the dealer have to deal with it?
Old Dec 2, 2009 | 08:54 PM
Venumb's Avatar
My first post here but I'll take a crack at helping you out...
You can reset your "Check Engine Light" using most code scanners. A lot of auto parts stores are beginning to refrain from doing this for you due to liability issues.
It could be your spark plugs simply need replaced, or a wire is loose..but more than likely your #5 coil pack is shot. I just had to replace that very coil pack on my daughter '06 Endeavour.
Best of luck!
Old Dec 3, 2009 | 06:38 AM
4never's Avatar
No need to worry, It turned off by itself after a few days of driving/starting. Glad I didn't have to deal with it with the dealer.
BTW, welcome to the site.
Old Dec 7, 2009 | 08:34 AM
Lithium's Avatar
What a coincidence! I had a misfire ('04 Endeavor) on a cold day a few days ago also. The check engine light went on a I also took it to Autozone to have them check it -- cylinder 2 misfire. About a day later, the check engine light went off and the car is driving fine. Should I do something about this?
triphex
Sep 9, 2013 06:51 PM
jay964
May 2, 2013 05:57 PM
triplenickle
Dec 31, 2012 01:26 PM
frankc
Jul 8, 2011 08:54 AM
Schmyggy
Jul 7, 2004 12:04 PM
