Montero stalls after 10 seconds of running.
Old Jun 21, 2014 | 02:39 AM
Robert Johnson's Avatar
Default Montero stalls after 10 seconds of running.
I am out of answers on what is wrong with my montero, I recently changed the timing belt that busted on my uncle, everything seemed fine except it kept stalling within 10 seconds. Finally found out it was the injectors that were being shut off, and once i reset the ignition they went on again. I have replaced the fuel pump, crank sensor, cam sensor, plugs, and wires. Can anyone give me some guidance or direction with this?
Old Jun 21, 2014 | 04:19 PM
mxmikie's Avatar
reset the ignition ????
Old Jul 10, 2014 | 09:04 PM
gentilessa's Avatar
1996 Montero/Challenger Automatic, Petrol/Gasoline - I am having a similar issue - but have not done any work on the car beforehand. When I turn the key it will start and run for 2 seconds then die as if there is no gas. If I turn the key til the lights are on (don't crank engine) and wait 5-10 seconds then start it - no problems. I have found a post for the diesel version of Monteros with the ICP sensor - is there a sensor for gas cars that is similar and could produce the same issue? I have checked the spark plugs, air flow, fuses and replaced the O2 sensor. What else could be wrong? Thinking it could be fuel pressure or a sensor somewhere... There are no computer faults or error lights of any sort to help me find the source...
Old Oct 21, 2020 | 02:57 PM
sboling's Avatar
I know this is a shot in the dark being so long ago, but i have a 2001 montero doing that dies intermittently. But it also kills injector pulse until the key is cycled. Any chance you figured out what the issue was??
Old Nov 6, 2024 | 01:57 AM
Wopwops's Avatar
Default Dies after 10 seconds
did you figure it out mines been off the road for 5 months
Old Nov 6, 2024 | 06:25 AM
whilst01's Avatar
Default stalling
Hi. Real puzzle. Sounds like the 'immobilizer'is shutting it off. Ckeck ignition surround on switch, key head for damage.
A long shot maybe but, worth a llook.
Old school me says, vacuum in fuel tank.
Keep us posted.
01monterob
23
Mar 29, 2015 11:44 PM
mobetta
Sep 28, 2009 12:50 PM
Bigfatso
Aug 17, 2007 04:56 PM
soundcolor
Mar 28, 2007 09:00 PM
GTinswva
16
Mar 6, 2007 05:05 PM
