Timing Belt Change Question/s
Old Aug 16, 2013 | 12:54 PM
RAYZOR1234's Avatar
Default Timing Belt Change Question/s
Hi all, I'm new to the forum as well as to the Endeavor. I am planning to do a timing belt change (120k miles), my original thoughts were that I would just change the belt and 2 pulleys but after some thought, do I really need to change the water pump and belt tension adjuster? Ive searched the forum and couldnt find an answer.
Thanks in advance.
Old Aug 16, 2013 | 05:51 PM
Akzle's Avatar
water pump, depends on condition when you get in there, idler pulleys/tensioner, yes, just do it.
Old Aug 16, 2013 | 06:49 PM
RAYZOR1234's Avatar
All "extra" parts are on order. Have to make a couple of the special tools but all should go well. Still cant believe no one in the baton rouge area carries a timing belt tensioner wrench, a flat bar with a couple of roll pins and a cutoff bolt for the torque wrench is cheaper anyway. Thanks
Old Aug 16, 2013 | 07:33 PM
Akzle's Avatar
ive never used one...
Good luck. Post pics for the next person who comes along and asks...
Old Sep 24, 2013 | 11:26 AM
petrencu's Avatar
Yes it is specified by constructor to change water pump and belt tension to with timing belt, warranty reason .
8000RPMS
Aug 30, 2007 05:49 AM
toddyfresh
Nov 26, 2006 07:20 PM
jneumann
Dec 20, 2005 05:39 AM
cptkid570
Oct 8, 2004 01:16 PM
galant4eva
Dec 31, 2003 04:49 PM
