Warning Light?
Old Feb 7, 2008 | 12:26 PM
rob985's Avatar
Default Warning Light?
I just bought a used 2007 Endeavor and I don't have a owner's manual. There is a yellow warning light on my dash that I can't identify. It is like a circle with an exclamation point in the middle. It is located on the lower right side of the dashboard gages. Can someone tell me what this light means.
Old Feb 8, 2008 | 12:23 PM
bamkmartin's Avatar
Default RE: Warning Light?
My WAG is that it is the tire pressure indicator. Try pumping up all of your tires to 32psi or so and see if it goes away.
Old Feb 9, 2008 | 10:25 AM
viprizza's Avatar
yeah i would say try the tire pressure and that should fix it..Had the same problem and that is what fixed mine.....
[/align]
Old Nov 24, 2008 | 08:20 PM
Spareair's Avatar
Well...hello fellow Endevour owners.....
My wife came to me...believe it or not to tell me about a light on her dash.........will wonders never cease.....
Well on to the issue....yes...I too found out that this light is the low tire pressure indicator......but my problem is different...
Living where I do I change the alloy rims for steel rims with winter tires.......now the computer thinks the tires are all low...
Is there a way to turn off the warning....blinking....flashing....strobe light that drives her crazy......and in turn drives me crazy?????
Old Nov 24, 2008 | 09:33 PM
4never's Avatar
I read something somewhere (maybe it was another Mitsubishi forum) but it said that you can possibily remove the fuse for the TPMS and it will turn that warning sign off.
Old Nov 28, 2014 | 09:07 AM
Trilla's Avatar
Most definitely the tire pressure
Old Jan 15, 2015 | 03:54 PM
garyst1981's Avatar
I have the same problem on my 06, at first it appear for a period of time and dissapear, then go back ON and now is always ON... what could it be? does the sensors inside the tires need batteries? is it a lot of work to replace them?
Old Jan 19, 2015 | 08:34 AM
Tyguy's Avatar
I'm also having the intermittent problem with mine. The tire pressures are all fine but the light is on occasionally. I just check the tire pressures when it comes on, then ignore it.
I do need to sell the car soon (family is outgrowing it) so id like it fixed if anyone has any solutions.
chevy047
Sep 1, 2007 08:10 PM
g1bishi
Nov 8, 2006 07:11 AM
waskull
Sep 6, 2006 08:30 PM
Mustang
Oct 22, 2005 03:30 PM
matt02708
May 18, 2005 08:32 PM
