2001 Eclipse GT Auto Transmission Problem
Old Sep 28, 2016 | 07:29 PM
Mikevv's Avatar
Default 2001 Eclipse GT Auto Transmission Problem
Hi, first time posting. Have 2001 eclipse gt. Today it ran and drove fine, until it was shut off. When we tried to start it again, it wouldn't turn over. Starter was sticking. Number ignition, eventually started, ran, and restarted fine when shut off. But, now the automatic transmission won't go in gear, not reverse, drive, or any of the sport gears to the right. When you move the shifter, there I's a slight rise in rpm like it is anticipating going into gear, and the dash gear indicators move correctly. Checked the relay in the engine compartment, swapped with the engine relay since they are identical, still no gears. Doesn't even slightly move like if it were slipping. Fluid is full, and it shifted and drove on 30 minutes before. Any help or advice is greatly appreciated.
agraves138
Oct 23, 2014 10:32 AM
Brand0n327
Mar 23, 2013 03:10 AM
Mitshi-VA
Jan 26, 2013 02:37 PM
davidvilla
Sep 23, 2011 09:53 PM
mysterio2099
Jun 8, 2006 06:33 PM
