400hp
Old Apr 7, 2007 | 02:50 AM
evoIX's Avatar
Default 400hp
Could anyone tell me whatI would have to do in order to achieve 400 bhp in my evo IX without performing mods to the inside of my engine(internals)?
Old Apr 7, 2007 | 10:56 AM
Default RE: 400hp
ORIGINAL: evoIX
you internals are good to over 500hp, so you dont have to worry about that. But im not totally sure what it takes with the IX. I know its definetly gonna require a turbo upgrade and some good tuning
Old Apr 7, 2007 | 11:17 AM
Default RE: 400hp
John your a newb. the IX does not need a turbo upgrade they make 400 Wheel HP easy all the time so 400BHP would be even easier.
Youll need these mod to get there or a little higher.
Turboback exhaust
MBC
cams
reflash
FMIC upgrade
Old Apr 7, 2007 | 11:40 AM
antlip's Avatar
Default RE: 400hp
He doesnt want to change internals though so cams would be out.
Old Apr 7, 2007 | 05:57 PM
Default RE: 400hp
ORIGINAL: antlip
since when are cams considered internals? cams are and easy mod to do you dont take anything out beside the valve cover
Old Apr 7, 2007 | 08:22 PM
antlip's Avatar
Default RE: 400hp
I consider anything that involves taking parts of the motor off to get to an internal. If you have to take off the valve cover and go inside of the head then I would consider that interals. Our views on this might be different.
Old Apr 7, 2007 | 08:35 PM
Default RE: 400hp
ORIGINAL: antlip
Internals are generally known to be crank pistons rods, anything inside the block. head not included. If I were to say head studs that is a little more understandable because you need to pull the entire head off, but cams are not that involved or expensive for the power gain you get out of it
Old Apr 7, 2007 | 11:48 PM
evoIX's Avatar
Default RE: 400hp
If u were to combinea manual boost controller, aem ECM, blow off valve, exhaust manifold, downpipe, and intake what do you think the horsepower to the flywheel wouldbe on average? Also, what is the size of the exhaust pipe on a evo IX in inches dia.? Is their really a need to increase the size of the exhaust while keeping the stock turbo setup?
Old Apr 8, 2007 | 12:29 AM
Default RE: 400hp
ORIGINAL: evoIX
Exhaust is a HUGE mod to do. def get a 3 inch exhaust. what is the ECM?
Old Apr 8, 2007 | 02:27 AM
XTREME's Avatar
Default RE: 400hp
Emonz, out of curiousity, where have you seen or heard of 400whp on an Evo IX with a stockturbo upgrade. From what I'veread the max that can be made is 375whp. Please show me and Evo IX that achieved this because I would be very interested as I'm looking for 400whp on my Evo IX.
