Blow off Valve??
Old Apr 25, 2007 | 01:04 PM
KLamkin04Evo's Avatar
Default Blow off Valve??
What is a good blow off valve for an 04 Evo??
Old Apr 25, 2007 | 01:07 PM
Dusty Eclipse's Avatar
Default RE: Blow off Valve??
I would suggest the Greddy myself... though, theres an interesting battle going on in another thread that you may want to read. https://mitsubishiforum.com/m_134434/tm.htm
Old Apr 25, 2007 | 01:34 PM
what are your plans, such as do you plan on any turbo upgrades and such. But a good upgrade is to get the stock evo 9 bov. It wont leak like the plastic one you have now which drops psi after like 16psi.
Old Apr 25, 2007 | 04:21 PM
JDM MR DV is a good one it is like $70 in most places and holds enough boost for the stock turbo to never max it out. otherwise I have a HKS SSQ which I no longer want on my Evo cause it is causeing compressor surge. I recommend looking into the Forge series. Im going to be getting the Forge RS in black (but it is super rare and very vry ard to get)
Old Apr 25, 2007 | 09:42 PM
GotBoost's Avatar
Emonz do you recommend i get rid of the hks on mine then??? You know my setup, is it ok or should I get something else????
Old Apr 26, 2007 | 12:30 AM
F.O.G.'s Avatar
I run a Tial FTW
Old Apr 26, 2007 | 02:32 AM
ORIGINAL: GotBoost
depends... does your car get compressor surge? mine does on the highway at 1\4 throttle and makes the car shake and stutter. and it acts like it is vented and stalls out sometimes like it is leaking at idle or something
Old Apr 26, 2007 | 06:41 PM
GotBoost's Avatar
My car has never stalled, sometimes the car does feel like it has a little sutter but not all the time, once in a while depending how im on the throttle, if im on the highway and doing 60-70 and give it a 1/4 throttle the car pulls slightly and then when I let off its more of a flutter blow off than the normal sound i get. My buddys speed 3 has the greddy type-s and that does the same as mine. Even if im on the highway and get on and off the throttle a couple times in a row I dont get like you do emonz. So this there a test or something I can do to simulate what you guys are talking about and see if mine does it too.
Old Apr 26, 2007 | 06:49 PM
You cant recirculate the tial
Old Apr 26, 2007 | 06:58 PM
GotBoost's Avatar
you cant????
