egr rode ???? help
Old Sep 12, 2007 | 11:00 AM
Evo2nv's Avatar
Default egr rode ???? help
thanks for the help guys that replied to my last post up evo's . I got a new question for you all.
Egr code keeps getting throw .
Install new egr ... same code gets thrown " egr flow insufficent "
Install new egr solinod .... once again same code "egr flow insufficent'
whats wrong with my car . they dealership " car max" is saying something could be clogged . please help is this common thanks
Old Sep 12, 2007 | 05:53 PM
Default RE: egr rode ???? help
did you do any work on the car before the light came on?
Old Sep 13, 2007 | 10:53 AM
Is there any other codes being thrown beside this. Id check the hoses going to the map sensor. Or you may have to replace the map sensor.
Old Sep 13, 2007 | 11:30 AM
Evo2nv's Avatar
Default RE: egr code ???? help
there as been no mods on the car yet. So far completely stock.
1st code with the egr valve
2nd code with egr solinod .
What else could be cause egr insuffiecent flow. The dealership said they checked all the hoses and what not. i dunno we'll find out.
Also my trany is shifting very stiff for me . The car as 27K on it and don't believe the trany , transfer case or rear end as been changed. is that bad ? and if so how often should i get it changed and what oils do you recomend.
Old Sep 13, 2007 | 06:03 PM
Tranny and T case SHOULD be done every 6k and rear end ever 15k. the owners manual says to do them every 15k ombined but the Tranny and T case dont like that as much and alot of big name shops recommends them at every second oil change
Old Sep 13, 2007 | 06:47 PM
ORIGINAL: Evo2nv
either clogged lines to the Map sensor, or a bad map sensor itself. I dont know of anything else
maylene
Jul 12, 2019 10:07 PM
lobsterman72
Aug 9, 2010 12:06 AM
robertz07reb
Nov 15, 2007 07:16 PM
gant
Apr 3, 2007 11:29 PM
wadea
Jul 26, 2005 12:42 AM
