misfire code
WELL CHECK THIS OUT.... i just put a turbo xs intake, 660cc inj, walbro fuel pump, 3 inch tbe, 3 inch rally cat, boost and wideband gauges, and ebc, and finally i got my car tuned. but i keep getting a check engine light with a misfire code. is this because of my injectors and fuel pump upgrade......need help fast im just trippin over that frikin ligh. thanx... by the way my car runs great still
Interestingly low mileage. Though, I doubt the car is throwing that code just to screw with you, lol. If its misfiring, see if maybe the plugs are covered in oil, or maybe fuel as you put the new injectors in... Maybe one of the injectors isnt even firing.
ORIGINAL: ComposeEvo
it's most likely mal-tunning, Your injector is not firing properly. Make sure there well grounded, test each one individually. Check for fuel as well as pulse.
Gus
Gus
jaystihl
Aug 18, 2021 06:06 PM
