misfire code
Old Sep 30, 2007 | 11:15 PM
antox18's Avatar
Default misfire code
WELL CHECK THIS OUT.... i just put a turbo xs intake, 660cc inj, walbro fuel pump, 3 inch tbe, 3 inch rally cat, boost and wideband gauges, and ebc, and finally i got my car tuned. but i keep getting a check engine light with a misfire code. is this because of my injectors and fuel pump upgrade......need help fast im just trippin over that frikin ligh. thanx... by the way my car runs great still
Old Sep 30, 2007 | 11:18 PM
Dusty Eclipse's Avatar
Default RE: misfire code
Odd that it would be a misfire code... I mean, 02 sensor I could see... Whats the code?
Old Sep 30, 2007 | 11:28 PM
antox18's Avatar
the code is p302
Old Sep 30, 2007 | 11:32 PM
Id check my plugs and wires before anything else there...
Old Sep 30, 2007 | 11:37 PM
antox18's Avatar
but this only happened after i put my injectors. plus i have 8k on my engine
Old Sep 30, 2007 | 11:42 PM
Interestingly low mileage. Though, I doubt the car is throwing that code just to screw with you, lol. If its misfiring, see if maybe the plugs are covered in oil, or maybe fuel as you put the new injectors in... Maybe one of the injectors isnt even firing.
Old Oct 1, 2007 | 12:12 AM
antox18's Avatar
thanks alot ill look into both things.
Old Oct 1, 2007 | 07:16 AM
Who tuned it? and with what? what does your wideband read threw out the rpm band
Old Oct 1, 2007 | 04:11 PM
ComposeEvo's Avatar
it's most likely mal-tunning, Your injector is not firing properly. Make sure there well grounded, test each one individually. Check for fuel as well as pulse.
Gus
Old Oct 1, 2007 | 07:11 PM
ORIGINAL: ComposeEvo
Gus
Im leaning on a lean AFR causing knock. Injectors are straight foward I mean in the Evo you dont need to splice the clips in them either so I would guess they possibly pooched the tune. AFR may tell the story
jaystihl
Aug 18, 2021 06:06 PM
newoutlanderfan
Dec 7, 2012 12:53 PM
nebeeseer
Nov 16, 2008 02:57 AM
maimunatu77
Sep 9, 2004 05:37 AM
Schmyggy
Jul 7, 2004 12:04 PM
