more ECU questions
Old Aug 5, 2007 | 08:49 PM
Mike21's Avatar
Default more ECU questions
Hey what’s up guys, need some help understanding a few things. I did read a few old post's and also got some info.
I’m in the process of doing an ECU flash. I really don’t wanna go on the route with a manual or electronic boost controller with an AFC or other piggy back systems.
Which would you guys recommend, Works or Vishnu? My goal is to have the ECU in total control. Works uses a “boost hose assembly”, which is able to modify the wastegate solenoid ECU maps….what does this mean exactly?
And on the other hand Vishnu’s stage Zero (v330) uses a “Passive Boost Solenoid Emulator”. How does this passive emulator work?
Thanks
Old Aug 6, 2007 | 09:11 AM
XTREME's Avatar
Default RE: more ECU questions
Mike21, I can't remember exactly how the Passive Boost Solenoid Emulator works butI do remember, through my research,it didn't allow the ECU to "completely" control the boost. The WORKS P2R flash and boost hose assembly is definitely the way to go if you want complete boost control through the ECU.
However, be aware the WORKS flash is more conservative than Vishnu, DynoFlash and other tuners mail in flash. WORKS goes for a smooth power curve and not so much peak numbers (better for daily driving). In the future, if you want more power, you'll have topurchase the Zeitronix wideband tuner and tweak their FLASH. ...this is what I did and I was able to extract another 22whp so far....
Old Aug 7, 2007 | 01:42 AM
Mike21's Avatar
Yeah I've been looking into WORKS too, they definately sound a bit more realiable. The P2R is part of their "Works Racing Program" and they also got a P2 flash. Is the differencebetweenthem the two-stage rev limiter?
Old Aug 7, 2007 | 08:55 AM
XTREME's Avatar
ORIGINAL: Mike21
If you have plans to eventually hook your laptop up to your Evo then two things; One, don't get the P2R because once you hook up your laptop you can change the rev limiter yourself. Two, get the P2 flash that doesn't use the ECUTek license (I believe it's the cheaper P2 flash) otherwise you won't be able to use your laptop to make changes to the a/f ratio, boost, or rev limiter.
McAdam
Nov 9, 2010 11:52 AM
nyc95gst
Jan 18, 2008 01:25 PM
Patrick
1st Generation
Apr 5, 2007 08:20 PM
illvibe311
Jun 30, 2006 10:07 AM
