Temperature
Old Feb 21, 2008 | 01:29 PM
5280LANEVO's Avatar
Default Temperature
When i drive my evo the temperature goes up to normal and then drops back down to below C. It will do this every time i drive it.Up and down up and down the whole time.It never stays.
Old Feb 21, 2008 | 05:46 PM
Default RE: Temperature
your check engine is not on right?
Old Feb 22, 2008 | 08:22 AM
sounds like possibly a thermostat issue
Old Feb 22, 2008 | 10:04 AM
ORIGINAL: TheEngineer
yup
Old Feb 23, 2008 | 09:59 AM
5280LANEVO's Avatar
Check engine light is on only because i keep spiking.So should i try a new thermostat.
Old Feb 23, 2008 | 11:19 AM
Your spiking what boost? do you have a MBC? I doubt that is the reason the light is on if thats the case. My car spikes like 27-28PSI on pump but only holds at 23
Old Feb 23, 2008 | 05:46 PM
5280LANEVO's Avatar
I posted a thread on my spiking,yes i have a MBC,im waiting for a boost gauge so i can turn it down.
Old Feb 23, 2008 | 05:56 PM
If you dont have a gauge then your prob not spiking your prob overboosting in general. Has you had the light code checked? why not just lower the boost controller all the way for now to be safe? otherwise you are risking your motor
Old Feb 29, 2008 | 10:46 PM
5280LANEVO's Avatar
I'll do that right now.But why is my temp going up and down? (I turned my boost down).
Psyclone
Mar 17, 2022 09:12 PM
clee
Jan 17, 2007 11:49 AM
vpellizzi
Jul 19, 2005 04:30 PM
cconner44
Feb 14, 2005 02:58 PM
M@NDRAXZ
Sep 30, 2003 08:54 PM
