-   Mitsubishi Evolution (https://mitsubishiforum.com/forum/mitsubishi-evolution-50/)
-   -   torque dampener or motor mounts? (https://mitsubishiforum.com/forum/mitsubishi-evolution-50/torque-dampener-motor-mounts-23640/)
Evo2nv Nov 22, 2007 10:10 AM
Which one is better ?
F.O.G. Nov 22, 2007 05:44 PM
RE: torque dampener or motor mounts?
I'd stick with the dampner. I have both on my car. The motor mounts transferred so much vibration that I put 3 of the stock ones back on. The damper is cheaper, easier to install and will work fine without the vibration transfer. How much HP / TQ are you making?
EMonz57 Nov 22, 2007 05:54 PM
Holy crap. FOG your back, where you been
Evo2nv Nov 22, 2007 07:48 PM
Well right now I am stock , full intake installed . Light weightcrank pulley .Upper and lower i/c pipe kit awaiting install , but have to order the mini race battery kit so i can install the i/c piping. I know the torque dampener is cheaper and easirer to install just wanna make sure its the right choice . Next year (feb/march)I am going to be installing full 3in turbo back exhaust , turbo header and o2 housing , fuel pump , reflash and bigger fmic. My goal is 400-450whp after i do cams and turbo upgrade. Is the torque dampener going to be go for that or once i break a certain whp should i go to the stiffer motor mounts.
EMonz57 Nov 22, 2007 08:21 PM
FOG is aking 630WHP if that helps
EMonz57 Nov 22, 2007 08:23 PM
To go off topic for a sec.
A video I made for FOG and his car as he is local to me
http://youtube.com/watch?v=-XhfLQ9ohwI
Evo2nv Nov 23, 2007 07:37 AM
does the optima batter really give you that much clearence for an upper i/c pipe kit. The weapon r i/c piping kit doesn't need all that much more room. Well sounds like the torque dampener is the way to go.
Evo2nv Jan 5, 2008 02:28 PM
just put my tq dampener in today and from my experience with stiffer motor mounts and now this i would def go with the tq dampener . you don't get nearly the vibrations the stiffer mounts can cause. great install , quick and easy.
Rob Jan 5, 2008 03:06 PM
ORIGINAL: Evo2nvThe weapon r i/c piping kit doesn't need all that much more room.
You can just trim the batter tray.
TheEngineer Jan 5, 2008 04:11 PM
I thought the IC piping is higher than the tray so how would cutting it make a difference. I know with the Ijen kit which emonz has you dont need a small battery kit, but if you get the buschur one you do. So i guess its dependant on the kit itself which i think the weaponr doesnt need the slim battery kit
