turbo
Old Mar 28, 2008 | 05:34 PM
Mike21's Avatar
Default RE: turbo
Did you get Head studs as well?
Old Mar 28, 2008 | 05:35 PM
Default RE: turbo
ORIGINAL: Mike21
Yeah, the FP Green does sound like a good deal. I'm getting a bit confused with the o2 housing and the hotside though. Is the o2 and the hotside the same? Is (2) and (3) two different pieces?
[/align]
you know better than that. Just look at the pic you can see there are bolts holding 2 on to 3. They are 2 peices. Hotside is part of the turbo. o2 housing is part of the exhaust really is the easiest way to put it. of course the hotside also passes the exhaust BUT that is where the turbine is spun.
Old Mar 28, 2008 | 05:38 PM
Default RE: turbo
it is highly recommended to get headstuds in the begining
Old Mar 28, 2008 | 05:50 PM
Mike21's Avatar
Default RE: turbo
it was jus a bit confusing cause ther are time that I meet other evo guys and they alyays recomend that I get the 10.5 cm hotside from the 06 or 07 evo's or maybe an aftermarket o2 housing, and I always got to remind them that the 10.5 hotsides started in the 05" VIII's.
I'll get the ARP Headstuds once I get the cams.....
Old Mar 28, 2008 | 05:55 PM
Default RE: turbo
Yes the 10.5 started in 05. 03 and 04s were 9.8s the o2 housings are the same. a ported o2 housing is a pretty good mod.
aznspyder
25
Nov 28, 2007 04:57 PM
turbotalon95
Jun 29, 2004 02:38 PM
scrappy24
Apr 7, 2004 11:04 PM
GSkiDD
Jan 29, 2004 08:04 AM
Eclipse_GSX
Jul 10, 2003 02:34 PM
