turbo timer
Old Feb 16, 2007 | 06:52 PM
  #21
silvercoupe97's Avatar
Default RE: turbo timer
ORIGINAL: fcukwithmeprelude
That's cool. I wish my turbo timer had a kill-switch hooked up to the ebrake.
But for a smart theif, could you just let the e-brake all the way down but one click, and drive away?
I suppose that could happen, but I think the ground wire is at the top of the pull, so once you release the lever, it should remove that ground from the circuit and shut the TT off then and not at the very bottom of the release....does that make sense?
If a thief were able to do that, that means that little ground point is grounded for as long as ebrake pull. My ebrake light shuts off as soon as I press the button and go down one click. My ebrake is still holding the inner drum pretty tight at that point still.
Xv7vX
May 25, 2007 01:48 PM
patfan7452
Aug 21, 2005 08:10 PM
bjoelson_gsx
Jun 7, 2005 12:24 AM
nate5023
Dec 24, 2004 10:52 PM
nate5023
Feb 25, 2004 09:05 PM
