Mitsubishi carisma 1999
Hi,
I have bought a Mitsubishi carisma 1999, 1.6. I am having trouble with the heating in the car, everything i have tried so far has failed. I have drained the radiator and filled this back up with the right amount of anti freeze, check for blockage. Anyone has any suggestions please
I believe you've posted in wrong section. .you might have better luck with responses if your posts/threads are in the specified location. .but since your new I guess you can have a break. ? Anyway about your heating issue have you made sure your fans are coming on. ? If so your themostate might be bad or incorrect I'm not sure what the Charisma is rated at but if you do change it out I woud suggest getting a lower temp thermo. . Good luck.
1999, antifreeze, ara, carisma, carizma, carsma, forum, forums, heating, micubishi, micubisi, mitsubishi, reg, system, ventilation
