-   Mitsubishi Galant (https://mitsubishiforum.com/forum/mitsubishi-galant-13/)
-   -   '00 GALANT TRUNK WONT OPEN W/ KEY OR LEVER (https://mitsubishiforum.com/forum/mitsubishi-galant-13/00-galant-trunk-wont-open-w-key-lever-26831/)
LITTLEPAULA Apr 8, 2008 03:42 PM
HI, I'M A NEWBIE HERE
I HAVE A 2000 GALANT...ANY HELP WOULD BE MUCH APPRECIATED:)
MY TRUNK WON'T OPEN WITH MY KEY OR WITH THE LEVER ..I'VE CRAWLED THRU THE BACK SEAT AND WAS ABLE TO OPEN IT ONCE PRIOR AND DIDNT EVEN KNOW WHAT I DID TO DO IT ,BUT IT'S JAMMED AGAINAND I CANNOT FIGURE HOW TO OPEN IT THIS TIME ...I'VE ALSO TRIED PUSHING THE WHITE SLIDE SWITCH TO LOCKAND UNLOCKUP AND DOWN AND HAD SOMEONE TURNING THE KEY WHILE I WAS IN THE TRUNK DOING THIS ....
CAN ANYONE HELP ME OUT WITH THIS ON WHAT I SHOULD DO TO OPEN IT FROM THE INSIDE???
THANX FOR TAKING THE TIME TO READ MY POST
westcoastryder Apr 19, 2008 11:36 PM
RE: '00 GALANT TRUNK WONT OPEN W/ KEY OR LEVER
I had the same exact problem. I went through the back seat and popped it open with a broom stick. After you open it spray the white slide switch with WD-40, that's getting stuck and can't move. Try that, should work for you too.
LITTLEPAULA Apr 21, 2008 12:21 PM
thank you , i will definetly try that.
i seen ur posting as well, and i also had that issue, i found that the radiator had cracked along the rim of it by the cap and nearly invisible ...i was only able to see it when i started the car and saw a slow leak, i had thought it was my fan too at first ,so i had to get it replaced. hopefully your radiators not metal and has been replaced with a plastic one ,the old model isnt built right....my friend also has the samemake and model and we seem to come across the same issues with this make and model kinda sad...
well in your case i really do hope its just the fan
skrookey Jul 30, 2012 11:24 AM
2000 galant truck wont open
wow , i thought this was just my problem. helped my son move .trunk worked. went to target trunk worked. came home trunk wont open. brought it in to get fixed . they have to order the whole trunk assembly and cost at least 200-300 $.
to fix they had to take backseat out. i only have the little opening and could not fit thru . although i tried for an hour.
so you think this is a defect???? maybe a call to mitsubishi to find out??
dkumar Dec 19, 2012 08:15 PM
Originally Posted by Florentinote (Post 288832)
I also encountered this problem, don't know how to solve
I had the same issue on 1999 Galant. It cost me 200 dollars to open it.
RonLH Jun 1, 2015 03:48 PM
Trunk lid won't open
Also had to go in through the back seat to open trunk. Takes about 10 minutes; unlatch seat bottom from under the front seat bottom. Move seat belts aside. Take out 3 bolts on bottom of seat back, and 3 bolts on back window ledge. White electric slide was broken in place, so move it out of way.
For 10 minutes work you save the dealer's $200.
