03 Galant a/c Issue
Old Jul 28, 2013 | 08:13 PM
ClassicSalsa's Avatar
Default 03 Galant a/c Issue
My a/c after driving for about 20 minutes shuts down and the green light starts blinking. If I shut down the car and start de engine again usually it works again and after 20 minutes it happens again. I replaced the dryer ,the a/c switch on the dryer and also the climate control unit and it still does the same.
The a/c is not leaking it has LP 30 and HP between 150-200. If I turn the a/c on and just leave the car out in the sun for an hour it works perfect very cold and it would not shut down but ones I start driving after a while it shuts down again. Also the compressor does not make any noise. We test the fans and they work perfect.
Any suggestions......
Old Jul 30, 2013 | 07:24 AM
Jeff Collision's Avatar
When the AC light is flashing, it is indicating that the system is being shut down to protect itself from pressure issues. In most of these cases, it is due to the refrigerant level being low. The most common leak point on this vehicle is the passenger-side top corner of the condenser in the front bumper. These things are notorious for failure, and it would happen several times a week during the hot seasons. A close second would be one of the hoses at the compressor that is somewhat common to leak.
Old Jul 30, 2013 | 11:49 AM
The issue is that the a/c is not leaking. We checked the refrigerant for the past 3 weeks and it always read 30. Do you think it should read more?
Mitsufahrer
Oct 29, 2007 12:40 PM
raff1ut
Feb 19, 2007 08:09 PM
sixpence
Jan 14, 2007 07:16 PM
Jasn1981
May 2, 2006 06:00 PM
reboot_dc
Aug 24, 2004 08:59 PM
